查看: 4348|回复: 6
[Firmware update] OSX issue
27
发表于 2016-8-22 18:32:23 | 显示全部楼层 |阅读模式
Hello !
My brand new TS100 is plugged using USB to my Macbook Air, DFU mode is enabled (v3.43) but I cannot see any new volume mounting anywhere.
Did I miss something ?
1995
发表于 2016-8-23 09:22:49 | 显示全部楼层
To try a few times more, UBS line connected to the MBA of USB2.0 interface, a disk volume label is a serial number, such as C2C3A3E7.
27
 楼主| 发表于 2016-8-24 21:29:13 | 显示全部楼层
[i = s] posts by loranger in 2016-8-24 21:48 Edit
I tried a lot, using a Macbook Air, an iMac and an Ubuntu box.
Nothing happens.
I took a look at dmesg but nothing is added when I plug the soldering iron in DFU mode (linux and osx).
By the way, nothing happens neither when I plug it in config mode.
Is there an issue with my TS100 ?
1995
发表于 2016-8-25 09:44:02 | 显示全部楼层
can you try in windows?
27
 楼主| 发表于 2016-8-26 21:05:44 | 显示全部楼层
That's not that easy.
I'll try to borrow one and tell you.
Thanks for your support.
27
 楼主| 发表于 2016-8-31 20:12:56 | 显示全部楼层
I just tried with a Windows 10 professional : As using Osx or Ubuntu, nothing happened.
What can I do ?
Am I supposed to contact my dealer' support in order to send my TS100 back ?
1995
发表于 2016-9-1 10:16:48 | 显示全部楼层
What can I d ...
Please contact the dealer to replace ts100
GMT+8, 2020-3-29 02:44 , Processed in 0.076366 second(s), 21 queries .
