查看: 4078|回复: 8
[第三方资源] TS100 Ralim 固件
1804
发表于 2017-7-25 11:50:55 | 显示全部楼层 |阅读模式
这是国外网友Ben Brown写的TS100第三方固件,方便单手操作,增加了很多功能,有兴趣的可以去GITHUB下载试试。
GITHUB地址:https://github.com/Ralim/ts100
YOTUBE视频介绍:https://www.youtube.com/watch?v=WlnpboYfxNk
介绍:
TS100
This is a complete rewrite of the open source software for the ts100 soldering iron. This project is feature complete for use as a soldering iron, so please suggest any feature improvements you would like! A short(ish) video that goes through every single menu option in the firmware is available over here
This project was started to remove the need for USB for changing system settings. In the latest official firmware they have also added a settings menu system, so it is still worth comparing the two firmwares to select your preferred option.
Please note that when running the iron off a Lithium battery pack, the Iron is only rated to 24V input. So using a fully charged 6S battery exceeds this rating, and is done so at your own risk. Please calibrate your irons voltage reading when you are using a lithium battery after any firmware upgrades.
Features
  • Soldering / Temperature control
  • Full PID iron temperature control
  • Automatic sleep with selectable sensitivity
  • Motion wake support
  • Settings menu
  • Set a voltage lower limit for Lithium batteries so you dont kill your battery pack. Please calibrate your input voltage first!
  • All settings saved
  • Improved readability Fonts
  • Use hardware features to improve reliability
  • Can disable movement detection if desired
  • Calibration of the temperature offset
  • Boost mode lets you temporarily change the temperature when soldering
  • Battery charge level indicatior if power source set to a lipo cell count.
  • Custom bootup logo support
57
发表于 2017-8-16 07:44:40 | 显示全部楼层
Well ! Useful article
15
发表于 2017-9-22 16:51:04 | 显示全部楼层
有没中文介绍啊,顶顶
1804
 楼主| 发表于 2017-9-22 16:54:19 | 显示全部楼层
avijwxfj 发表于 2017-9-22 16:51
有没中文介绍啊,顶顶
哥,google翻译吧
这个固件很好用
15
发表于 2017-9-22 16:59:17 | 显示全部楼层
去看了,看不懂,注册了也不知道该下载哪个,有没大神,转过来?
1804
 楼主| 发表于 2017-9-25 09:07:50 | 显示全部楼层
https://github.com/Ralim/ts100/releases
releases里面,就是各种历史版本的下载
发表于 2017-10-28 23:26:23 | 显示全部楼层
好用(*/ω\*)
发表于 2019-4-17 17:13:24 | 显示全部楼层
比官方固件要陈旧  撒情况  该用哪个?
7
发表于 2019-5-10 19:21:13 | 显示全部楼层
60982230 发表于 2019-4-17 17:13
比官方固件要陈旧  撒情况  该用哪个?
谁说陈旧的,没看是2019年1月29日更新的固件吗。。。
RC4 : RC3 rebuild to fix no show issues
@Ralim Ralim released this Jan 29, 2019 · 14 commits to master since this release
Rebuilt on different compiler.
Works fine on my local units, but hopefully has more success with others.
If you are reporting an issue please include the exact file name used from the release.
More fixes on RC2,
This release has TS80 support and more fixes to it.
Some oscillation in the TS80 is occurring at the moment, as it needs slightly better tuning, but it works well once warmed up. (Oscillation is only during heating).
If you have more issues / feedback for this release please put it in #422
If you open other new issues about bugs, these will be closed*
Use the hex files unless you know you need to use bin files.
GMT+8, 2019-5-26 21:05 , Processed in 0.056511 second(s), 21 queries .
© 2001-2017 Comsenz Inc.
