查看: 11570|回复: 0
[The 3rd party resources] TS100 Ralim firmware
1995
发表于 2017-7-25 11:52:54 | 显示全部楼层 |阅读模式
GITHUB:https://github.com/Ralim/ts100
YOTUBE:https://www.youtube.com/watch?v=WlnpboYfxNk
TS100
This is a complete rewrite of the open source software for the ts100 soldering iron. This project is feature complete for use as a soldering iron, so please suggest any feature improvements you would like! A short(ish) video that goes through every single menu option in the firmware is available over here
This project was started to remove the need for USB for changing system settings. In the latest official firmware they have also added a settings menu system, so it is still worth comparing the two firmwares to select your preferred option.
Please note that when running the iron off a Lithium battery pack, the Iron is only rated to 24V input. So using a fully charged 6S battery exceeds this rating, and is done so at your own risk. Please calibrate your irons voltage reading when you are using a lithium battery after any firmware upgrades.
Features
  • Soldering / Temperature control
  • Full PID iron temperature control
  • Automatic sleep with selectable sensitivity
  • Motion wake support
  • Settings menu
  • Set a voltage lower limit for Lithium batteries so you dont kill your battery pack. Please calibrate your input voltage first!
  • All settings saved
  • Improved readability Fonts
  • Use hardware features to improve reliability
  • Can disable movement detection if desired
  • Calibration of the temperature offset
  • Boost mode lets you temporarily change the temperature when soldering
  • Battery charge level indicatior if power source set to a lipo cell count.
  • Custom bootup logo support
Settings Menu
This menu allows you to cycle through all the options and set their values. The button near the tip cycles through the options, and the one near the usb changes the selected option. Note that settings are not saved until you exit the menu, and some settings such as screen flip do not apply until a power cycle is applied. If you leave the unit alone (ie don't press any buttons) on a setting, after 3 seconds the screen will scroll a longer version of the name
  • PWRSC -> Power source, select a cell count if using a LiPo, or DC to disable the shutdown. (Sets it to minimum of 10V).
  • STMP -> The temperature the unit drops to in sleep mode
  • SLTME -> Sleep time, how long it takes before the unit goes to sleep
  • SHTME -> Shutdown Time, how long the unit will wait after movement before shutting down completely
  • MSENSE -> Motion Sensitivity,0*9,0 means motion sensing is turned off, 9 is most sensitive, 1 is least sensitive (ie takes more movement to trigger)
  • TMPUNIT -> Temperature unit, C or F
  • TMPRND -> Temperature Rounding, {1,5,10}
  • TMPSPD -> How fast the temperature should update in the soldering status screen.
  • FLPDSP -> Flip display for left handed users
  • BOOST -> Enable boost mode
  • BTMP -> Set the temperature for the boost mode
Temperature rounding means that the unit will round off the temperature before displaying. This can helpt to reduce the flickering of the temperature when the unit oscillates between two temperatures.
GMT+8, 2020-3-29 09:56 , Processed in 0.048371 second(s), 21 queries .
