查看: 3139|回复: 2
[Troubleshooting] How to calibrate the voltage measurement?
发表于 2017-10-5 08:49:07 | 显示全部楼层 |阅读模式
Hi,
I just bought a DS202, and the voltage measurement is off. I have a very accurate voltage source that reads 5.01V DC on my accurate voltmeter, but the DS202 reads something like 4.87. I wouldn’t mind if it was off by ± 0.05V or maybe even 0.1V given that it’s inexpensive, but tolerances for my project are ± 0.25V so I need something with significantly better calibration.
I know there is “auto calibrate,” but how does that work? How does it calibrate? I saw mention of it calibrating zero, but does it also calibrate the scale in any way?
Is my DS202 defective?
Thank you!
277
发表于 2017-10-16 09:38:50 | 显示全部楼层
Select "calibration" in Page3 "calibrate zero" option and then press the "S" to perform the calibration procedure
20
发表于 6 天前 | 显示全部楼层
感谢楼主分享
GMT+8, 2020-10-24 07:46 , Processed in 0.092164 second(s), 21 queries .
