查看: 3371|回复: 7
[Troubleshooting] TS100 always restarts when press button A
7
发表于 2018-5-17 05:10:02 | 显示全部楼层 |阅读模式
[i = s] posts by Renoise in 2018-5-17 05:14 Edit
Hello! Just received my new TS100 (v2.18) - but it's not heating up. When I plug in 24v 3a power supply, the TS100 boots up, shows v2.18 firmware and then tells to press button A, but when I press it - it doesn't heat up and just restarts again. When I press button B, it shows 24.15v and room temperature.
Here are settings in my config file:
StbTemp=200   #(100~400)
WkTemp=300    #(100~400)
SlpTime=180   #(60~999)
IdlTime=360   #(100~999)
TempStp=10    #(1~25)
OffVolt=10    #(5~19)
Temp=0        #(0,1)
Hand=0        #(0,1)
ZeroP_Ad=239  #ReadOnly
So, what's wrong and why it's not working????? Please help!
45
发表于 2018-5-17 09:41:13 | 显示全部楼层
The power is too big. Try it with a smaller power supply.
7
 楼主| 发表于 2018-5-18 01:20:29 | 显示全部楼层
Why 24V 3A is too big?? It is ideal power supply according to TS100 manual which clearly says: 24V voltage and >2.7A current gives 65W power and 11 seconds to heat up from 30℃ to 300℃ - isn't?
I tried it with 18V 0.17A and 12V 400mA - the same problem, when pressing button A the TS100 just restarts. Please help what's wrong??
45
发表于 2018-5-18 09:42:38 | 显示全部楼层
Press the "A" button to restart the black screen, is there any error message?
45
发表于 2018-5-18 09:45:35 | 显示全部楼层
Renoise 发表于 2018-5-18 01:20
Why 24V 3A is too big?? It is ideal power supply according to TS100 manual which clearly says: 24V v ...
You should try to see if version 2.12 firmware has the same problem, if there should be a problem with this TS100.
45
发表于 2018-5-18 11:24:00 | 显示全部楼层
18V 0.17A and 12V 400mA are not acceptable.
7
 楼主| 发表于 2018-5-23 01:58:04 | 显示全部楼层
I tried 2.11 and 2.12 firmware - the same problem. It is definitely something wrong with official firmware, because when I installed ralim firmware - everything started working immediately like a charm.
45
发表于 2018-5-24 09:37:50 | 显示全部楼层
That may require a close examination, which has not been encountered before.
GMT+8, 2020-11-25 10:12 , Processed in 0.047942 second(s), 20 queries .
