查看: 2076|回复: 5
[疑难问题] Format 8MB Storage
8
发表于 2019-2-6 23:09:36 | 显示全部楼层 |阅读模式
Can I reset 8MB Storage?
It does not work with Linux. I formatted it, now I also does not work with Windows. Can I reset 8MB storage?
Also is English manual available? Is firmware available?
8
 楼主| 发表于 2019-2-11 04:01:13 | 显示全部楼层
Solved
1965
发表于 2019-2-13 08:57:49 | 显示全部楼层
Can you try in win7?
8
 楼主| 发表于 2019-2-24 06:14:07 来自手机 | 显示全部楼层
It works on windows, doesn't work on linux. Will it be possible to add support?
1965
发表于 2019-2-25 09:25:39 | 显示全部楼层
Yes , we will work on it.
5
发表于 2019-5-17 01:27:46 | 显示全部楼层
This fixed my problem:
  1. sudo dd of=/dev/sdd if=/dev/zero status=progress
  2. sudo mkfs.fat -F 12 /dev/sdd
  3. mkdir -p /tmp/p
  4. sudo mount /dev/sdd /tmp/p -t msdos -o "fat=12"
复制代码
The device files will be available in /tmp/p
GMT+8, 2020-2-27 09:08 , Processed in 0.345212 second(s), 21 queries .
