楼主: minidso
[Firmware update] Material Download for DS213 Oscillloscope
21
发表于 2019-8-6 05:19:04 | 显示全部楼层
Sadly the 1.22 cannot be compiled as DispDrv.c under Program/PUBLIC has a lot of unresolved references. u8, u16 and u32 can easily be fixed with adding #include <stm32f10x.h> but   LCD_W_Block(0, 0, COL_SIZE, ROW_SIZE); are all not available, I guess that may come from sources which are not included in the zip or am I missing something? Waiting for the new version anyway.
发表于 2019-8-6 09:18:43 | 显示全部楼层
thank you for your kindly
16
发表于 2019-12-18 05:02:32 | 显示全部楼层
I posted a question, but I have the answer now
43
发表于 2020-2-8 05:13:23 | 显示全部楼层
Is the firmware to fix the single trigger mode being worked on?  Has there been any progress?  What is the estimated completion date?
2137
 楼主| 发表于 2020-2-8 12:23:28 | 显示全部楼层
caykroyd 发表于 2020-2-8 05:13
Is the firmware to fix the single trigger mode being worked on?  Has there been any progress?  What  ...
Still need to wait, no date set
22
发表于 2020-3-12 23:44:00 | 显示全部楼层
2020.03.12: DS213 APP 2.14 + FPGA018:
Any comments will follow?
2137
 楼主| 发表于 2020-3-13 09:40:58 | 显示全部楼层
Fix some bug.
发表于 2020-4-23 22:45:31 来自手机 | 显示全部楼层
Is this scope useful ds213 for automotive applications.to test fuel injectors oxygen sensors
2137
 楼主| 发表于 2020-4-24 09:12:35 | 显示全部楼层
Yes, can test fuel injectors oxygen sensors
发表于 2020-5-19 04:29:26 | 显示全部楼层
How to save settings, so that they are the same when you turn power on again?
Each time I turn DSO on, the settings are back to defaults.
GMT+8, 2020-12-5 01:59 , Processed in 0.053495 second(s), 20 queries .
