查看: 2107|回复: 4
[疑难问题] Problem with firmware upgrade
38
发表于 2019-3-6 01:34:02 | 显示全部楼层 |阅读模式
Thank you for the latest firmware for DS213.But I couldn't upload the file to the oscilloscope, the file copy progress cuts off midway then it shows "the file is too big for the file system".
After that, the drive turns inaccessible. (The drive has 1.96MB of free space and the file takes 1.2MB)
I've also tried with K2 button, changing the file extension and name, but nothing got to success.
I'm using Windows 10 64bit Home edition with Korean language set. What can I do?
感谢您为DS213提供最新固件。
但我无法将文件上传到示波器,文件复制进度中途切断然后显示“文件对文件系统来说太大”。(该驱动器有1.96MB的可用空间,文件占用1.2MB)
之后,驱动器消失,设备的固件没有变化。
我尝试了K2按钮,更改了文件名和扩展名,但没有任何改变。
我正在使用带有韩语语言设置的Windows 10 64位家庭版。 我能做什么?
1965
发表于 2019-3-8 10:35:52 | 显示全部楼层
请格式话U盘为“FAT”格式,然后更新固件试试。
8
发表于 2019-3-9 23:25:32 | 显示全部楼层
not working still
1965
发表于 2019-3-11 09:19:40 | 显示全部楼层
Can you try an other computer? WIN7 is better.
38
 楼主| 发表于 2019-3-13 10:18:05 | 显示全部楼层
Eventually I found a way.
1. Change the file name to "._" without the quotation marks.
2. Copy it to the drive root.
3. Restore the file name to the original one.
By doing this, you can copy the firmware file to the drive without any errors.
However, there was also an error. The file's extension changes to .err after copying and nothing changes.
竟然我找到了一种方法。
1.将文件命名为“._”。 不要包含引号。
2.将文件复制到驱动器。
3.恢复文件名。
这将允许成功将文件复制到驱动器。
然而,也有一个错误,扩展名更改为.err,并且没有任何变化。
GMT+8, 2020-2-27 09:01 , Processed in 0.121757 second(s), 21 queries .
