查看: 26757|回复: 63
[第三方资源] Open Source
16
发表于 2019-3-17 05:36:26 | 显示全部楼层 |阅读模式
Has the firmware source code been released yet? Can the open source firmware for the DS203 (Wildcat) be used / easily ported?
Thanks!
36
发表于 2020-3-26 16:53:44 | 显示全部楼层
You're welcome!
回复 支持 1 反对 0
2535
发表于 2019-3-18 09:29:15 | 显示全部楼层
Yes, It's in the plan. Please wait.
回复 支持 1 反对 0
16
 楼主| 发表于 2019-3-18 18:03:04 | 显示全部楼层
Thanks! I follow you on Twitter, would be great if you could announce a source code release or tweet about any neat open source projects that appear.
11
发表于 2019-5-27 00:25:11 | 显示全部楼层
I am so excited about this device. It has so much potential.
236
Rank: 3Rank: 3
发表于 2019-9-8 16:52:21 | 显示全部楼层
Speaking of Open Source, the DS213 isn't really open.
There is sources for the main application. But without fpga spi protocol description and without fpga design sources, we can't extend DS213 features or fix bugs.
We do see how the app attempts to communicate with fpga, but we can't verify if that's correct at all.
I have reasons to believe the fpga side is responsible for triggering issues. It reports "EMPTY" status bit right at the trigger position, so application will stop reading waveform right there. Altering the application, and attempting to read beyond that point - just reads out the last sample taken.
Any chances fpga side info will be made available?
2535
发表于 2019-9-9 09:21:11 | 显示全部楼层
There is sources for the main application. Bu ...
Yes, We have plan to open source the FPGA later.
13
发表于 2019-11-10 03:35:47 | 显示全部楼层
I bet all sources will become open after DSO215 (if any) release
I hope they'll fix trigger issue before it
43
发表于 2020-1-23 22:23:36 | 显示全部楼层
Is there any update on release the code to open source or fixing the trigger bug.  When will it be fixed?
36
发表于 2020-2-29 18:09:03 | 显示全部楼层
Hello all,
I succeeded to implement a software workaround concerning the "trigger issue".
With this modified software now, the DS213 seems to work well.
I share the following .HEX file for any one that would like to test it.
This is an unofficial version (1.22.a)
Please try and give a feedback.
DS213_FW_22_a.zip
35.6 KB, 下载次数: 700
trigger bug fix
91
发表于 2020-2-29 22:54:15 来自手机 | 显示全部楼层
Corto123 发表于 2020-2-29 18:09
Hello all,
With this ...
https://github.com/gabonator/DS203/issues/44
Try this
GMT+8, 2022-10-2 23:35 , Processed in 0.139632 second(s), 25 queries .
