楼主: RoosterCogburn
[第三方资源] Open Source
235
Rank: 3Rank: 3
发表于 2020-3-1 05:15:10 | 显示全部楼层
Corto123 发表于 2020-2-29 18:09
Hello all,
I succeeded to implement a software workaround concerning the "trigger issue".
With this ...
What's the nature of workaround? To me it looked mostly like a race condition, and a lack of proper synchronization between cpu and fpga. I gave it up trying to make those run along smoothly.
36
发表于 2020-3-2 17:52:54 | 显示全部楼层
The length of responses seem limited on this forum. Please look at the file attached.
fix_explanations.zip
637 Bytes, 下载次数: 282
235
Rank: 3Rank: 3
发表于 2020-3-2 19:31:26 | 显示全部楼层
Hello all,
With this ...
Definitely helped with Single trigger mode, but it still erratic in Auto mode.
Connecting channel A to inbuilt signal generator, it stops updating the screen above 20mS/div
36
发表于 2020-3-2 22:20:44 | 显示全部楼层
Thank you for the feedback. Can you post a screenshot?
235
Rank: 3Rank: 3
发表于 2020-3-3 16:35:19 | 显示全部楼层
https://imgur.com/a/K1lK5jO
36
发表于 2020-3-3 20:49:03 | 显示全部楼层
Thank you! I made some tests in auto mode: you are right there are side effects..
I will try to restore official strategy for auto mode only.
36
发表于 2020-3-3 21:50:39 | 显示全部楼层
The strange display you observed is, in my opinion, due to the exact synchronization between the FPGA and the CPU.
The CPU generates the FPGA clock (1Mhz x 10) and the sampling rate is the exact multiple of the output frequency.
So each sample can correspond to the same position on the signal shape.
However the auto mode has to be fixed. I work on a correction.
36
发表于 2020-3-4 20:30:34 | 显示全部楼层
Hello, I post a new version that fixes some side effects with the AUTO mode. Please try and give any feedback.
DS213_FW_22_b.zip
35.75 KB, 下载次数: 241
91
发表于 2020-3-4 20:52:26 来自手机 | 显示全部楼层
I tried A and B versions and both works fine for me in auto,norm and single mode,  B version just reload signal curve with less time than A, trigger in single mode from left side of table(see trigger mode chart) is gone, that is good job, maybe this two apps works fine because I have fpga from 1.20.
91
发表于 2020-3-4 21:43:22 来自手机 | 显示全部楼层
darkonerakot1 发表于 2020-3-4 20:52
I tried A and B versions and both works fine for me in auto,norm and single mode,  B version just re ...
Just find out 1.22b contain bug, auto trigger if you move scale to right
GMT+8, 2021-9-19 10:44 , Processed in 0.132279 second(s), 20 queries .
