楼主: RoosterCogburn
[第三方资源] Open Source
36
发表于 2020-3-5 00:08:38 | 显示全部楼层
Thank you for your observations. I am not sure to understand your last post.
Can you describe more precisely the scenario that is causing the problem? Does it appear in AUTO mode?
91
发表于 2020-3-5 01:48:09 来自手机 | 显示全部楼层
Can you describe more  ...
I mean 1.22b auto mode works but if you change xpos to right bug appears
36
发表于 2020-3-5 16:09:53 | 显示全部楼层
I think this is not really a bug: panning on the trace is meaningfull when the acquisition is stopped.
I don't think that any DSO could show a trace in real time far from the trigger point..
In my opinion, in 'RUN' mode:
- The view position should set to 0 (most left position).
- The panning function should be disabled.
43
发表于 2020-3-5 22:28:43 | 显示全部楼层
I have tried to copy the .hex to the DS213 by holding pause and turning on the device.  After copying the .hex to the root directory, It replace the .hex with a .ERR file.  Is this an FPGA hex file?  If so, can you provide the procedure to upload this to the DS213?  Do I need to upload two different .hex files in two different ways?
Thank you for the help.
91
发表于 2020-3-5 22:56:52 来自手机 | 显示全部楼层
Corto123 发表于 2020-3-5 16:09
I think this is not really a bug: panning on the trace is meaningfull when the acquisition is stoppe ...
You didnt get, it is not in pause, all bugs I were telling  about is in moment of measurement, you just measuring signal and right at this moment change xpos and signal get distortion and freezes.
255
Rank: 3Rank: 3
发表于 2020-3-5 23:07:35 | 显示全部楼层
Corto123 как раз и пишет о том, что, с его точки зрения, PANNING и не должен работать пока работает RUN. Т.е. PANNING имеет смысл только в режиме PAUSE.
91
发表于 2020-3-5 23:45:53 来自手机 | 显示全部楼层
firebie 发表于 2020-3-5 23:07
Corto123 как раз и пишет о том, что, с его точки зрения, PANNING  ...
Ну я не согласен, а если отладка устройства идет? Каждый раз паузить и скроллить?а если пик искомого искажения не кратный несущей? Так вообще  тяжко, я хз, то что он предлагает это какой-то регистратор чтоли.
6
发表于 2020-3-6 02:57:33 | 显示全部楼层
@caykroyd, I had the same problem on my windows 7 pc but when I tried it on a windows 10 pc it worked without a problem.
91
发表于 2020-3-6 03:34:35 来自手机 | 显示全部楼层
MG3100 发表于 2020-3-6 02:57
@caykroyd, I had the same problem on my windows 7 pc but when I tried it on a windows 10 pc it worke ...
There is one solution, same thing happened when I extracted his file with standart winzip, .err it is how device shows about error, I guess, just extract .hex file with 7zip and youll get .rdy wich I think means all is ok!
255
Rank: 3Rank: 3
发表于 2020-3-6 04:22:24 | 显示全部楼层
It is better to unpack the file to hard drive and then copy it to device.
GMT+8, 2020-12-4 14:06 , Processed in 0.066113 second(s), 18 queries .
