楼主: RoosterCogburn
[第三方资源] Open Source
43
发表于 2020-3-7 00:20:17 | 显示全部楼层
Yes, I got it to install correctly.  Drag/drop from zip to DS213 doesn't work.  Note to others... unpack file first, then upload.
Regarding new firmware, It does work better, I have still found many bugs that make it very difficult to use.  I will try to compile a list and add here if you think it will be helpful.
261
Rank: 3Rank: 3
发表于 2020-3-8 22:56:32 | 显示全部楼层
May be it would be better to start a new project on github? It has much better support for issues and so on.
2295
发表于 2020-3-12 16:06:40 | 显示全部楼层
Already fix the bug, Please download APP 2.14 here:
http://www.minidso.com/forum.php?mod=viewthread&tid=3357
235
Rank: 3Rank: 3
发表于 2020-3-13 01:28:50 | 显示全部楼层
While it doesn't stop now at the trigger position, the overall behavior is quite weird. Video (136MB)  https://we.tl/t-m4bavTzrWZ
2295
发表于 2020-3-13 10:22:17 | 显示全部楼层
Volhott 发表于 2020-3-13 01:28
While it doesn't stop now at the trigger position, the overall behavior is quite weird. Video (136MB ...
Please try falling edge trigger and rising edge trigger.
When the waveform stops refreshing, please try to pause and start to see if it is refreshed.
91
发表于 2020-3-14 01:18:31 | 显示全部楼层
just tested it, bugs in norm mode xpos change 200ms, freq mesurement etc, tl th auto bug, Zoom in out is locked now in pause, this is good decision there is no bug if there is no option.
235
Rank: 3Rank: 3
发表于 2020-3-15 21:40:30 | 显示全部楼层
It fails the same with edge trigger. RUN/HOLD restart is on video.
43
发表于 2020-3-20 01:53:06 | 显示全部楼层
There is a new bug in latest firmware.  At power up the volume is defaulted to highest.  It only changes after hitting the menu button.  Very annoying.  Note:  I do not actually have to change the volume percentage when entering the menu.  I only have to enter the menu for the preset volume to take effect.
2295
发表于 2020-3-20 10:18:07 | 显示全部楼层
caykroyd 发表于 2020-3-20 01:53
There is a new bug in latest firmware.  At power up the volume is defaulted to highest.  It only cha ...
Enter the menu option, adjust the appropriate power on parameters and press K3 to save, then change the power on default value
43
发表于 2020-3-22 09:28:09 | 显示全部楼层
minidso,
The volume at power up is 100%.  I have saved the volume to 5% in the menu.  I have confirmed that the 5% is saved by doing a power cycle.  The problem is that at power up the volume remains at 100% until I enter the menu.  I do not need to change the volume as it shows 5%.  Only by entering the menu (without changing the volume setting) does the volume go to the proper 5%.
GMT+8, 2021-9-17 20:18 , Processed in 0.120262 second(s), 19 queries .
