楼主: RoosterCogburn
[第三方资源] Open Source
52
发表于 2020-3-28 07:15:45 来自手机 | 显示全部楼层
Interesting since the fpga fix the encoder wheels are now unresponsive/skippy/jumpy, seems as though maybe they've turned off interrupts for the encoders and are now polling for wheel changes, or maybe slowed down the polling rate so its missing events, or maybe cpu is more busy handling events from fpga?? Just my stab in the dark
91
发表于 2020-3-28 16:21:18 | 显示全部楼层
1.22d    1uS 500ns -> freq mesurement in auto mode buggy, but in norm mode it works just fine, 1000MHz is enough for me now, @Corto123, you made really usable firmware, I really hope Ill unite with @gabonator and after exchange of experience the perfect firmware will be released.
36
发表于 2020-4-27 00:40:10 | 显示全部楼层
I would like to post a new version.
But the upload fails.. This forum is really difficult to use. I will try later.
36
发表于 2020-4-27 15:06:33 | 显示全部楼层
Upload failed again.. any suggestion is welcome to solve this recurrent issue.
261
Rank: 3Rank: 3
发表于 2020-4-27 17:38:08 | 显示全部楼层
Can you create account on github and post link here?
36
发表于 2020-4-28 00:32:28 | 显示全部楼层
drive.google.com/file/d/1AHWqzU4gSNDELBciUXBNwjqHP76XBmgM/view?usp=sharing
261
Rank: 3Rank: 3
发表于 2020-4-28 02:25:58 | 显示全部楼层
Thank you for fixed version.
I have a question about 1.22.e version - "release notes.txt" says that "After power on, first sampling starts immediately." - but in my case after power is on - device is on "HOLD".
36
发表于 2020-4-28 16:59:20 | 显示全部楼层
You're welcome.
HOLD mode is set on power off.
"After power on, first sampling starts immediately." means there is no more unexpected delay before getting a correct waveform display, the first time you start a sampling (RUN).
This is a bug fix.
91
发表于 2020-4-30 04:33:47 来自手机 | 显示全部楼层
Corto123 发表于 2020-4-28 16:59
You're welcome.
"After power on, first sampling starts immediately ...
Thx a lot, you did some serious work in it.
43
发表于 2020-5-7 22:56:35 | 显示全部楼层
Corto123,
Are you ready for feature requests???? ;-)   I have one... when taking a screenshot with the triangle and play/pause button, I would like to access that screenshot without power cycling the scope or re-inserting the USB cable... Any chance that is possible?
Thanks.
GMT+8, 2021-9-17 20:34 , Processed in 0.117034 second(s), 18 queries .
