查看: 1373|回复: 1
[其他] Data export
发表于 2019-4-20 12:45:41 | 显示全部楼层 |阅读模式
Dear DSO213 developpers and users,
I wonder if there is a way to export files from the DSO213 internal disk to a computer via USB, and then display the data on a computer ?
Menu allows "SaveWave", "SaveBuff" and "SaveCSV". I would have expected SaveWave would save raw data, SaveBuff some kind of screen image (?) and SaveCSV a CSV format file. But when I explore the disk, I only see .DAT files that look empty.
Thank you in advance,
38
发表于 2019-4-23 18:12:14 | 显示全部楼层
Data export is an official feature of DS213. By using that menu, you can.
Just do SaveCSV, then a .scv file will appear on the disk.
What's not official is that you can't do it while the usb cable is plugged in.
More specific, you can't see any internal change on the disk while connected, despite pressing refresh button in the exploler.
So unplug then plug it again, you'll see the .scv files you've created.
I'm not sure it'll be fixed later, but it's inconvenient anyway.
数据导出是DS213的官方功能。 通过使用该菜单,可以。
只需执行SaveCSV,然后.scv文件将出现在磁盘中。
什么不是官方的是,它不能在usb电缆插入时这样做。
更具体地说,尽管在浏览器中按下刷新按钮,但在连接时你无法看到磁盘上的任何内部更改。
拔掉然后重新插上它,你会看到你创建的.scv文件。
我不确定它会在以后解决,但不管怎么说都不方便。
GMT+8, 2020-5-29 18:24 , Processed in 0.085981 second(s), 20 queries .
