查看: 1194|回复: 3
[疑难问题] Screenshot is empty
5
发表于 2019-5-17 01:45:22 | 显示全部楼层 |阅读模式
Hi,
I did some tests and all my screenshots are empty.
2041
发表于 2019-5-17 15:01:44 | 显示全部楼层
The bmp file have 47KB, You can't open it?
5
 楼主| 发表于 2019-5-18 09:56:16 | 显示全部楼层
Nops, I did a
dd
from my last partition image and it fixed the problem, it appears that the screenshot does not work if the serial/license file is deleted.
2041
发表于 2019-5-21 09:26:42 | 显示全部楼层
Please try to re-flash the firmware and format the flash disk as "fat"
GMT+8, 2020-6-6 09:30 , Processed in 0.056885 second(s), 24 queries .
