Warning: Do not connect any power input and output when updating the firmware!
2021.07.26:
MDP-M01 & MDP-P906 APP V1.32: download
- Solve the bug of M01 screen stuck;
- Improve the compatibility of P906 with the power supply head with PD protocol;
-Make the display of output voltage and current value more stable.
2022.06.16:
MDP-M01 User Manual V3.3: download
MDP-M01 User Manual Russian Version V3.3: download
MDP-P906 User Manual V1.0: download
MDP-P906 User Manual Russian Version V1.0: download
2021.06.06:
MDP-M01 APP V1.31: download
-Optimized the bug that the voltage and current lines overlap when the waveform is dynamic.
2021.07.26:
MDP-M01 & MDP-P905 APP V1.30: download
-Fix the bug that the channel number of the power supply will change when M01 adjusts the voltage and current.
- Optimized the power-on self-check of P905, which can be connected to a relatively poor power bank;
-Added the function of automatically releasing residual charge.
- Solved the bug that read and write files abnormally when the serial port function is opened.
2021.06.15:
MDP-M01 & MDP-P905 User Manual V3.2: download
2020.09.17:
MDP-M01 & MDP-P905 APP V1.25: download
-Add PC control function;
- Change the rotation direction of the knob, which corresponds to the knob direction of the power supply.
- Lock and save function, the original lock state can be maintained even when the machine is restarted;
- When the voltage or current is optimized and adjusted, the corresponding current or voltage value will flicker;
-Add output switch function;
2020.09.17:
MDP-M01 APP V1.23 & MDP-P905 APP V1.24: download (Stop download)
-Added the function of adjusting the volume of the display control;
-Increase the color of the adjustable power pulley lights;
- Added the function of deleting and exchanging power supply equipment information;
-Optimized the range of the waveform graph, and added the waveform display function of one-key full range or auto range;
- Speed up the reading and writing speed of U disk;
- Improve the speed of screenshots.
- Increase the stability of wireless connection.
- Optimized the power-on self-test, and can be used on a relatively poor power bank;
- Solve the bug that the U disk reads files abnormally under win10.
- Added the function of long pressing the SET and MENU buttons for 3 seconds to manually shut down.
- Increase the power-on verification process.
- Solve the bug that the input current is abnormal (the power display will display "INPUT ELEC ERROR") due to the residual charge inside the device, please see the special instructions below;
-Added a shortcut key to force exit from U-disk mode after long-pressing any key for 3 seconds in U-disk mode.
- Turned down the brightness of the display to increase the life of the display.
2019.10.22:
MDP-M01 APP V1.21 :
MDP_M01_v1.21.zip
(85.55 KB, 下载次数: 1617)
