查看: 1290|回复: 6
[Firmware update] Firmware questions and suggestions
30
发表于 2019-8-8 08:35:20 来自手机 | 显示全部楼层 |阅读模式
When are you going to release the source code for the software in the MDP-M01?  There are a few things I would like to fix.
-> Rolling the "menu" wheel away from you should move the cursor up, or in the case of changing the voltage should move the cursor to the left.  Rolling the wheel towards you should move the cursor down or in the case of changing the voltage should move the cursor to the right.
-> Rolling the "value" wheel away from you should increase the value, rolling it towards you should decrease it.
-> When you first power on the MDP-M01 the far left soft key is blank until you either press it or switch to another screen and back to the "wave" screen, then it shows "Modify" like it should.
-> There is no option to set the key volume on the MDP-M01.
And also a suggestion, you should make a multimeter module to go with this set, that would make it a pretty versatile tool.
Thanks!
2066
发表于 2019-8-8 09:18:13 | 显示全部楼层
Thank you for your suggestion.
We will open source code as soon as possible
30
 楼主| 发表于 2019-8-9 05:04:19 | 显示全部楼层
I also saw that there are other planned modules (Digital Signal Generator, Electronic Load, Power Charger, Battery Pack), is there any rough estimate on when they might be available?
Also, what type of wireless do they use to communicate?  Is it possible to develop 3rd party modules that would work with the MDP-M01?
2066
发表于 2019-8-9 10:01:04 | 显示全部楼层
Other modules can communicate with the display module via 2.4G.
Display module can control 6 devices
30
 楼主| 发表于 2019-8-11 21:58:06 | 显示全部楼层
When will other modules be released?
2066
发表于 2019-8-12 09:13:10 | 显示全部楼层
We are work on it. maybe later of this year.
30
 楼主| 发表于 2019-8-14 00:35:25 | 显示全部楼层
Another feature request, please add support for fahrenheit temperature display.
Thanks!
GMT+8, 2020-7-16 02:29 , Processed in 0.049966 second(s), 21 queries .
