查看: 740|回复: 2
[Troubleshooting] defective power unit
4
发表于 2019-9-27 18:31:34 | 显示全部楼层 |阅读模式
I received my power supply yesterday. unfortunately the power unit does not seem to work. When I connect it to a USB-C cable or using the power port it refuses to power up. I also tried to get access via usb to upload new firmware but again no succes. The display control unit does power up normally.
Any suggestions what could be the cause?
4
 楼主| 发表于 2019-9-28 21:49:48 | 显示全部楼层
Here a link to a video illustrating the defect: https://photos.app.goo.gl/DQxNqFMqgt2vGLpu7
1958
发表于 2019-10-8 09:40:19 | 显示全部楼层
What power supply you input?
In the video is a 9V batter?
Can you try other power supply?
GMT+8, 2020-2-23 05:43 , Processed in 0.069146 second(s), 21 queries .
