查看: 301|回复: 6
[疑难问题] DS213 needs to be fixed!
19
发表于 2019-10-4 23:18:20 | 显示全部楼层 |阅读模式
It has been 5 months or more since we have had a useless oscilliscope.  There have been many reports of the trigger function not working.  There have also been requests for the FPGA source code so the community can attempt to fix the bug.  Many of us have spent a lot of money on this tool and it is useless.  Can you please provide the fix and/or the source code as soon a possible?
There has been no communication of when it will be completed.  And if there is no solution can you please provide information on how we can return these scopes for a full refund?
Thank you.
27
发表于 2019-10-7 05:11:42 来自手机 | 显示全部楼层
My centements exactly. It will be ashame if this scope turns out to be permanently broken due to some unfixable design flaw?! Minidso you have kept us waiting for way too long for your promised fixes, and open-source developers have said they cannot do anything with thevDS213 until they get the code for the fpga. So please, you owe us all an explanation what exactly is the problem and why is it taking so long? Not just 'we are working on it'!
27
发表于 2019-10-7 07:59:04 来自手机 | 显示全部楼层
roops67 发表于 2019-10-7 05:11
My centements exactly. It will be ashame if this scope turns out to be permanently broken due to som ...
Sentiments not centements dope !
9
发表于 2019-10-7 15:34:50 | 显示全部楼层
Quite true, I'm sonstantly checking this site for updates but there's just nothing, well a schematic appeared a while back but I've been waiting for an actual update or the source code so I can actually work with the device. This doesn't really make miniware look good, to be honest.
1901
发表于 2019-10-8 09:43:29 | 显示全部楼层
Sorry , we are fixing the bug of trigger. Will release soon.
27
发表于 5 天前 来自手机 | 显示全部楼层
The please in the meanwhile release the fpga code, then open-source developers like the guys behind wildcat firmware can get to work on it
发表于 5 天前 | 显示全部楼层
roops67 发表于 2019-10-15 06:19
The please in the meanwhile release the fpga code, then open-source developers like the guys behind  ...
Yes, I prefer wildcat firmware support DS213.
GMT+8, 2019-10-20 13:50 , Processed in 0.856818 second(s), 21 queries .
© 2001-2017 Comsenz Inc.
