查看: 1680|回复: 8
[其他] TS80 Bad screen
发表于 2019-10-6 22:32:32 | 显示全部楼层 |阅读模式
Hello minidso,
I recently purchased a TS80 and the screen is really dark. Almost unreadable in any light.
I've tried emailing guangzhoumorningtrade@gmail.com with pictures but have yet to get a response.
Is there way to replace the display or fix this issue?
Thanks,
Matt
138
Rank: 7Rank: 7Rank: 7
发表于 2019-10-14 13:53:25 | 显示全部楼层
The problem had been replied by email, please check,thank you.
发表于 2019-12-30 05:05:27 | 显示全部楼层
I have same problem. Tried emailing guangzhoumorningtrade@gmail.com with no response too.
138
发表于 2019-12-30 11:24:27 | 显示全部楼层
chosenone 发表于 2019-12-30 05:05
I have same problem. Tried emailing  with no response too.
Sorry, could you provide your email for us to check you email, we will solve the problem ASAP.
发表于 2020-2-14 21:11:18 | 显示全部楼层
I have the same problem.
Is a solution found?
138
发表于 2020-3-5 17:39:28 | 显示全部楼层
Hi, sorry for the late reply.
Please send an email to our email address guangzhoumorningtrade@gmail.com with pictures or videos about your problem and let us know what makes it happened.
11
发表于 2020-9-7 18:02:07 | 显示全部楼层
Hi
I have the same problem. After some use, suddenly the lcd is very bright, almost nothing can be seen on it.
What is the solution for repair?
138
发表于 2020-9-8 10:32:05 | 显示全部楼层
igorsimo 发表于 2020-9-7 18:02
Hi
I have the same problem. After some use, suddenly the lcd is very bright, almost nothing can be s ...
Hello, customer
If any questions with the products, please send an email to service@morningtools.com with pictures or videos about your problem.
Thank you.
发表于 2020-10-3 07:10:24 | 显示全部楼层
I need help with a bad screen on my TS80P, too.  I tried contacting miniware through the "contact us" tab, but I haven't received a response.  Can you please help me get my TS80P repaired? The screen is completely blank, but the unit otherwise works.
GMT+8, 2020-10-22 02:16 , Processed in 0.058265 second(s), 20 queries .
