查看: 683|回复: 3
[Troubleshooting] Firmware Update Failed - P905 Unit Inoperable
发表于 2019-10-20 23:23:53 | 显示全部楼层 |阅读模式
After connecting the P905 unit to my Windows computer in DFU mode, I copied MDP_P905.hex to the "DFI V3_64_D" drive. However, when the copy reaches 50%, the P905 disconnects from my computer and I get the error:
After doing this, my unit no longer functions. When I plug in the normal power input, the display does not turn on.
How can I restore functionality to my unit?
Thank you!
1958
发表于 2019-10-21 09:30:54 | 显示全部楼层
Can you get in the DFU mode now?
发表于 2019-10-23 00:40:35 | 显示全部楼层
I have the same problem; when I drop the MDP_P905.hex file onto the DFU drive, it reboots and returns MDP_P905.err.  Now the P905 won't boot anymore; it immediately enters DFU mode on power-up (even when not holding the set button).
Is there anything I can try?
1958
发表于 2019-10-23 08:35:28 | 显示全部楼层
glambx 发表于 2019-10-23 00:40
I have the same problem; when I drop the MDP_P905.hex file onto the DFU drive, it reboots and return ...
Please try upgrade by bin file:
MDP-P905 APP V1.21 (Upgrade via bin file):
http://minidso.com/forum.php?mod=viewthread&tid=3696
GMT+8, 2020-2-22 08:29 , Processed in 0.103878 second(s), 21 queries .
