查看: 344|回复: 5
[疑难问题] DS213 unusable after update to 2.14
5
发表于 2020-5-4 03:11:44 | 显示全部楼层 |阅读模式
Thanks for solving the trigger bug, but the new software bricked my DS213.
I followed the steps in the readme:
1. Copy FGPA_CFG.ADR to the DFU disk. The DFU disk restarts and shows FGPA_ADR.SET
2. Copy STMU_213_018.bin to the DFU disk. The DFU disk restarts and shows STMU_213_018.rdy
3. Copy DS213AppV1.24.hex to the DFU disk. The DFU disk restarts and shows DS213AppV1.24.err
Now when I restart the device it shows
   FGPA Configuration err!
   Please load the FGPA Data.
Whatever I try, this error is returning.
Even restoring V1.22 does not solve this problem.
What can I do to get the device working again?
87
发表于 2020-5-4 06:26:44 来自手机 | 显示全部楼层
There is full backup of 1.20 on github but you need 5$ device to flash it
2036
发表于 2020-5-5 09:11:06 | 显示全部楼层
Can you change a computer to flash?
Better in WIN7.
87
发表于 2020-5-5 23:14:51 来自手机 | 显示全部楼层
Better in WIN7.
Nah, this is not that case, it issue about broken fpga.
2036
发表于 2020-5-7 09:14:28 | 显示全部楼层
The other case, Same probrom, USE win7 to upgrade, Can fix it.
发表于 2020-5-20 01:00:08 | 显示全部楼层
Hi, minidso, I like your products, have multiple of them, but this one really needed a fw update so I did try and I have the same problem (got broken when flashing through Mac OS, via Android it would complete ignore the uploads). I tried then flashing on Win7 and Win10, but the the last 3rd step - uploading the hex file always fails with err, please help.
As last resource, is the HW flashing documented somewhere?
I even have corrupted splash logo, when I tried to upload one of the files multiple times.
Thanks.
GMT+8, 2020-5-29 18:32 , Processed in 0.104117 second(s), 21 queries .
