返回列表 发新帖
楼主: emaliy
[固件更新] ===DS0201袖珍示波器固件更新===
277
发表于 2015-4-3 09:12:13 | 显示全部楼层
wsycy99 发表于 2015-4-1 18:19
请问下这些固件是有分类的吗?比如V1的只能用V1的固件升级 V3的只能用V3的固件升级?我的是V3.26D,把固件 ...
只分DS201和DS201 Pro
5
发表于 2015-4-6 01:22:53 | 显示全部楼层
sagittarius 发表于 2015-4-3 09:12
只分DS201和DS201 Pro
明白了,谢谢您
发表于 2016-1-9 11:45:02 | 显示全部楼层
amigo eu tentei atualizar meu osciloscópico mini dso 201 com a versão 201v5  mais deu errado agora ele so exibe digital storge osciloscópico tem como eu da um reset nele me ajudem agradeco
2036
发表于 2016-1-11 10:33:44 | 显示全部楼层
natalino 发表于 2016-1-9 11:45
amigo eu tentei atualizar meu osciloscópico mini dso 201 com a versão 201v5  mais deu errado agora ...
  Sorry that I can not write in Portuguese but English. You would try to upgrade the latest DS201 firmware with V4.30 first, and then select Calibrat"CA" options "Restore".
    Should you have any further questions, please feel free to contact us.
Regards,
发表于 2016-1-14 09:06:39 | 显示全部楼层
Friend I tried to update my dso201 following as shown in the manual, but now appears only digital storage osciloscope wanted to know the procedure to return to factory configuration
thankful if his friend can help
发表于 2018-4-15 11:21:34 | 显示全部楼层
我的DS201是2011年买的,版本是V2.6,我按升级说明开机后,映射的盘符不是DFU 。。。,而是可移动磁盘K,点击打不开,说未格式化,无反应。后来看了V2.6以下的升级说明贴,装了ST的工具,但只能进DFU模式,只能找DFU格式的文件升级,但没有看到比2.6新的版本啊。这个帖子全是HEX的文件,请问我怎么升级
2036
发表于 2018-4-17 09:06:48 | 显示全部楼层
http://minidso.com/forum.php?mod=viewthread&tid=47
这个太旧了,翻翻旧贴吧
发表于 2018-12-4 13:51:12 | 显示全部楼层
发表于 2019-10-7 16:15:18 | 显示全部楼层
开机显示DS0201+, 是不是就是201Pro?
点评
发图看看  发表于 2019-10-8 09:18
发表于 2020-5-6 08:59:50 | 显示全部楼层
这个网站还活这么?我没法下载任何一个附件。
GMT+8, 2020-5-29 17:43 , Processed in 0.187670 second(s), 22 queries .
