查看: 159|回复: 4
[疑难问题] Display shows noise
6
发表于 2020-6-25 11:00:22 | 显示全部楼层 |阅读模式
Hi. My power module is showing noise in the display. It gets worse as I try to navigate trough the menu. The device is new, it is the first time I use it. I have updated the firmware but still the same.
I have tried to upload a picture but it failed every time.
Thank you.
6
 楼主| 发表于 2020-6-25 22:47:06 | 显示全部楼层
6
 楼主| 发表于 2020-6-27 05:48:31 来自手机 | 显示全部楼层
https://share.icloud.com/photos/01OLExzh1xLeb7QL6lTsMVvng#Chihuahua
6
 楼主| 发表于 2020-6-27 06:12:37 | 显示全部楼层
The previous post is a link to a picture of the problem.
Here is what I have tried:
-Upgrade firmware of both
-Downgrade and then upgrade again
-Different power supplies (both USB, plug, batteries)
-Different cables
When the device is in DFU it shows the serial number and DFU version correctly
100
Rank: 7Rank: 7Rank: 7
发表于 2020-6-29 10:18:08 | 显示全部楼层
Hello, customer.
If any questions with the products, please send an email to service@morningtools.com with receipt and videos about your problem.
Thank you.
GMT+8, 2020-7-16 01:02 , Processed in 0.118287 second(s), 20 queries .
