2022.06.28:
DT71 Calibration V1.11:download
2022.03.04:
DT71 Firmware V1.15:download
- Fixed the problem of detecting the continuous pressing of capacitive buttons
2021.12.01:
DT71 Mini Digital Tweezers User Manual V1.2:download
2021.11.08:
DT71 Firmware V1.13:download
- Added judging DFU version number
- Modified some automatic calibration parameter ranges
- Improve some capacitance calculation methods
- Perfect compatibility with older versions of DFU
- Fixed screen flipping issue
- Modify the order of automatic calibration gears, put R0 before V0
- Modify auto-calibration C11 range value
- Modify NV gear configuration
2021.08.10:
DT71 Mini Digital Tweezers User Manual V1.1:download
2020.12.31:
DT71 Firmware V1.08:download
DT71 Mini Digital Tweezers User Manual V1.08:download
- Auto-calibrate capacitor subdivision
- U disk parameters increase capacitive button touch sensitivity
- Manually measure the voltage range to increase the floating judgment, and the floating display "---"
- Modify the version number
- Modify auto-calibration parameter range
- NV file PA4 pull down
- Modify the negative voltage judgment value
- Modify the voltage value to clear the BUG
2020.11.06:
DT71 Firmware V1.06: download
- Shield debug interface
- Change the initialization U disk data
- Changed the configuration sequence when auto-calibration voltage calibration is switched to resistance
- Added battery display
- Modify the judgment range of automatic calibration parameters
- Increase the judgment of the Y-axis angle switch corresponding to the display direction, the angle can be selected by the user: 10~60
- Correct spelling mistakes in calibration prompt characters
- During automatic gear detection, if the auxiliary value is less than 0.1, the auxiliary value will not be displayed
-Fixed the inaccurate display of battery power in different gears
- When the waveform gear is switched to calibration, the screen characters are not clear
2020.09.04:
DT71 Mini Digital Tweezers User Manual V1.05: download
DT71 Calibration Instructions: download
