查看: 10459|回复: 4
my ds201 pro
13
发表于 2014-9-13 23:59:38 | 显示全部楼层 |阅读模式
我有问题ds201pro,停留在主屏幕上,并不会仅此而已。
硬件版本1.0
型单片机STM32F103VC
LCM CTRL ILI_9341
USB DISK内部8MG
 如果连接到电脑,而不是招呼都不打U盘。
发生什么了?
我怎样才能解决呢?
谢谢。
13
 楼主| 发表于 2014-9-14 00:16:39 | 显示全部楼层
I have problems with ds201pro, stays on the home screen and does nothing more.
hardware version 1.0
Type mcu STM32F103VC
LCM CTRL ILI_9341
USB DISK INTERNAL 8MG
  IF CONNECTED TO THE COMPUTER, NOT ACKNOWLEDGE ME usb disk.
What happens?
How I can solve it?
Thank you.
When I turn it on, it stays dormant, I've tried everything to no avail. More so than I can not access it from the PC.
How I can make a RESET?
13
 楼主| 发表于 2014-9-14 00:17:44 | 显示全部楼层
LCM CTRL ILI_9341
What happens?
How I can solve it?
Thank you.
13
 楼主| 发表于 2014-9-14 00:22:29 | 显示全部楼层
LCM CTRL ILI_9341
What happens?
How I can solve it?
Thank you.
MY ds201 pro...
MY ds201 pro...
277
发表于 2014-9-15 09:36:28 | 显示全部楼层
hardware version 1.0 ...
In the interface, is holding down the "OK" button turn on, look at the pictures of the machine, "OK" button has been holding down,   it maybe  stuck.
GMT+8, 2020-2-23 21:21 , Processed in 0.056071 second(s), 24 queries .
