查看: 134118|回复: 50
[Firmware update] Material Download for TS100 mini Soldering Iron
2137
发表于 2015-8-3 15:58:44 | 显示全部楼层 |阅读模式
2020.08.05 Update:
TS100 User Manual V1.0.3 : download
TS100利用者マニュアル V1.0.2バージョン: TS100利用者マニュアル V1.0.2バージョン.pdf (5.9 MB, 下载次数: 10802)
6
发表于 2017-5-11 16:19:11 | 显示全部楼层
[i = s] posts by FreeMaxl in 2017-5-11 16:32 Edit
minidso Posted 2017-5-11 09:39
We will soon release app V2.17, and source code of app V2.17
OK, first of all, You have done well good work on the Firmware ! Thank you.
So I just relax and wait for your V2.17 source-code release.
I just have some Ideas:
In Version 2.16 the Parameters for Sleep- and Idle-Time are (low)limited to 60 or 100 seconds.
I think its a good Idea to set the low-limits to 15 and 25 seconds. (if someone feels comfortable with short standby times)
(for myselfe I really often use the two-Buttons to switch-off the soldering Iron)
The Parameter "OffVolt" have an upper Limit from 12V:
I use the TS100 on my Motobike-travvels.  So I want to protect Battery from discharge.  Therefore the Parameter for "OffVolt" should be settable to higher Values.  I think 16 V is a good upper Limit for this Parameter.
If the Source-Voltage gets lower then the "OffVolt" Setting the Display just resets.
I think its better when first a Message is printed on the Display "! Low-Volt !" and then a wait-time of 3 seconds bevore the program go further. (so that the message is readable)  I think when the Voltage gets too low, a "global" wait-time is really ok. (because its a problem)
Maybe you want to change some of this in a possible 2.18 release. (or in 2.17 if it is not too much work)
回复 支持 1 反对 0
4
发表于 2015-8-27 04:47:34 | 显示全部楼层
Do you have the .hex file?
I can not compile the source code. I do not have IAR 6.4.
4
发表于 2015-12-19 03:55:05 | 显示全部楼层
Hello I got two of this this super solder irons. They ar really great! But now one of them is not working properly... I can´t make the logo working. I upload a LOGOIN.bmp file and the space in the solder iron is smaller but after I start the iron, the old logo is visible. When I upload a new picture the space on the stick is smaller again... but it doesn´t work. The other one is working fine. I have made an fw upgrade... Please help. Thank you ;)
2137
 楼主| 发表于 2015-12-21 11:05:23 | 显示全部楼层
The logo file name must LOGOIN.bmp, and the details is:
Now if  you TS100 does't work , You can try to upgrade the TS100 APP 2.11 .
192
发表于 2016-1-12 16:09:33 | 显示全部楼层
APPV211.zip
APPV21N.zip
35.8 KB, 下载次数: 6970
zip版
16
发表于 2016-8-5 20:57:08 | 显示全部楼层
hello to all
recently I bought a iron soldering ts100.  but it has not worked. . I disassembled and saw that one simply does not soldered capacitor. on electric circuit he have #23. tell him capacity. that I could find a replacement.
thx.
2137
 楼主| 发表于 2016-8-8 09:47:10 | 显示全部楼层
C23 is designed to be empty, so there is no capacity.
Could you explain how the soldering is not working? What does it display on the LED screen?
What power supply do you use? If you use 12V power supply, the current must be more than 1.5A.
16
发表于 2016-8-9 03:26:28 | 显示全部楼层
Could you explain how the soldering is not w ...
I use 12V and 3A power supply.
When I click on the button immediately terminates heating.
for greater understanding link for video.
youtube link
Thx
2137
 楼主| 发表于 2016-8-9 09:30:12 | 显示全部楼层
Open config.txt
edit  "Turn_Off_v=10   #(9~12)"
try turn_off_v=9
If TS100 still can't work. Please check your power supply, and recommend the use of 19V 2A power.
5
发表于 2016-8-24 23:18:47 | 显示全部楼层
Hello. you can do APPv212.hex for the left hand?
GMT+8, 2020-12-5 01:55 , Processed in 0.068543 second(s), 25 queries .
