楼主: minidso
[Firmware update] Material Download for TS100 mini Soldering Iron
2036
 楼主| 发表于 2016-8-25 09:38:39 | 显示全部楼层
johncomp 发表于 2016-8-24 23:18
Hello. you can do APPv212.hex for the left hand?
We leave this opportunity for TS100's fans.
发表于 2017-3-4 09:53:00 | 显示全部楼层
[i = s] posts by dmr in 2017-3-4 21:52 Edit
Can you include in next firmware option so we could set lower values for waiting standby time (like 5-10 sec) and lower standby temp (for example 50C)
2036
 楼主| 发表于 2017-3-6 09:27:49 | 显示全部楼层
Changing these two parameters is very simple and can be considered
发表于 2017-3-7 12:19:39 | 显示全部楼层
Thank you very much. It would be very helpful because heating time is really low so waking from sleep is very fast.
发表于 2017-4-16 09:43:02 | 显示全部楼层
johncomp Posted 2016-8-24 23:18
https://goo.gl/QKreNR
update firmware and config your setting from config.txt
发表于 2017-5-5 18:15:56 | 显示全部楼层
Hi There, Ive just received my brand new TS100 and love it....so Ive updated the firmware to your latest - 2017.4.28 Update : TS100 APP 2.16 however after update on my TS100 the version is showing V2.15 open startup, not 2.16, so am I correct to assume that the correct firmware is now on my TS100 and the version number needs to be updated on the released file?
2036
 楼主| 发表于 2017-5-8 17:27:05 | 显示全部楼层
Sorry, We forget to edit APP2.16 'logo.
We will fix it in 2.17
发表于 2017-5-9 00:29:11 | 显示全部楼层
It would be great to get the English version of the changelog for firmware v2.16.
6
发表于 2017-5-11 01:43:19 | 显示全部楼层
Hello, can you post the source-code of last release ?
TS100 APP 2.16
In the .rar file is just the .hex file.
Or where can I find the source-code ?
thanks
2036
 楼主| 发表于 2017-5-11 09:39:26 | 显示全部楼层
FreeMaxl 发表于 2017-5-11 02:18
Hello, can you please post the source-code for last Version ?  (APP V2.16)
Or where can I find the  ...
We will soon release app V2.17, and source code of app V2.17
GMT+8, 2020-6-1 23:58 , Processed in 0.117239 second(s), 19 queries .
