楼主: minidso
[Firmware update] Material Download for TS100 mini Soldering Iron
14
发表于 2018-1-2 23:12:13 | 显示全部楼层
it is possible add on future upgrade firmware?
14
发表于 2018-1-2 23:14:00 | 显示全部楼层
is it possible to add input voltage calibration?
10
发表于 2018-1-22 12:25:40 | 显示全部楼层
请问温度调整范围是否可以支持最低至50度?谢谢
2137
 楼主| 发表于 2018-1-22 17:19:49 | 显示全部楼层
官方固件最高支持400度
6
发表于 2018-2-1 02:19:58 | 显示全部楼层
When will V2.18 be available for download?
发表于 2019-1-9 12:11:13 | 显示全部楼层
Hard to confirm information to get pertinent datasheet.
Is there a method to obtain PCB and TS100 firmware version through USB, read from Flash.
TS100 is working with 19V 3.5A supply. TS100 firmware ver 2-18 is installed.
USB connection can update temperature parameter. As per 7.2 Default Parameter Setting of Instruction Manual Version 1.0.1
Very Nice.
发表于 2019-5-23 11:25:18 | 显示全部楼层
Hello,how can I find the source code for DFU mode?
发表于 2019-7-29 19:53:15 | 显示全部楼层
I just got the TS 100.
Great Soldering Iron.
I only suffer from low Offvolt 12v.
Please make it up to 20v  in the next firmware.
Thanks a lot.
发表于 2020-2-28 09:46:06 来自手机 | 显示全部楼层
Does the 19.5v adapter 4.65A damage the device?
144
Rank: 7Rank: 7Rank: 7
发表于 2020-3-5 17:45:43 | 显示全部楼层
Before connecting DC5525 (12-24V) power adapter, check if the adapter is in good condition as below standard.
We would recommend the DYS404-190210V (19V, 2.1A) power supply as an accessory for TS100.
Thank you.
GMT+8, 2020-12-4 09:44 , Processed in 0.055132 second(s), 19 queries .
